15 years ago1) Two paths just means there is more than one combinatorial path.
2) rx_clk is a clock. I don't see it in the code but it certainly is. 3) rx_clk is also a data path, i.e. it feeds itself. This is known as clock-as-data, and is generally correct. Note that when your clock is data, both rising and falling edges are relevant, which is also correct. (An example would be sampling a slower clock into a faster clock). 4) The question is if the analysis is correct. It's basically when a falling edge out of rx_clk|q wraps around and feeds back inot rx_clk|d and is clocked in by clk. I'm actually surprised this could be a hold violation. Breaking out the full path is probably necessary. Do you have a generated clock statement on rx_clk?
