12 years ago
Problem with design project for Quartus (device - MAX II)
Hellow.
I want develop some project on EPM570GM100I5N (MAX II family), but I can't find this device (and other G MAX II devices ) in Quartus II 12.1sp1 Web Edition (64-Bit). How can I solve this problem (I should change device (for example EPM570ZM100I8N) or I should download some addition for Quartus)?
    Ok. I just got a answer from my FAE on this issue: (Thank Dave Smith for the Answer!)
    o target your device, manually enter the part in the Quartus II
    Settings File (.qsf) by performing the following steps:
    Close the project
    Open <project>.qsf in a text editor
    Locate the line set_global_assignment -name DEVICE <device code>
    Change the setting to the device you are targeting
    As an example, for the part EPM2210GF256I5, the syntax would be
    set_global_assignment -name DEVICE EPM2210GF256I5
    Exclude the N (lead-free) indicator if that is applicable to
    your part
    Save the updated file
    To verify your changes, perform the following steps:
    Open your project
    On the Assignments menu, click Devices
    Verify that Target device has the Other: option selected and is set
    to your device
    In this example, EPM2210GF256I5
    Why quartus doesn't list the G variation I don't know. But it does work. I compiled a simple design just to verify and under device and pin options for Voltage, it lists the VCCINT as 1.8V instead of the 3.3V for the F variation that I initially started the project with.
    Pete
    And anybody know, does it really work with real device when I'll programm it?
