Problem with compiling host code in VS 2010 and emulation
I am trying out the simple vector addition example given on Altera website. I have AOCL 14.1, Quartus 14.1 and VS2010 installed. I am able to compile the OpenCL kernel without any problem.
However, when I try to compile the host code in VS2010, I get the following error: alteracl.lib(acl_globals.obj) : error LNK2019: unresolved external symbol acl_hal_get_system_definition referenced in function acl_init_from_hal_discovery I also found that for some reason, VS2010 is not able to read the file# include "CL/opencl.h" as this appears with a red underline. The other issue I have is with emulation. AOC always complains that it cannot find the Visual Studio LINK.EXE though I have clearly included it in the path system variable : C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\amd64 Any help would be greatly appreciated.6 Replies
I have been able to resolve the AOC unable to find VS LINK.EXE. I was trying emulation from within SoC embedded shell. That was wrong. I switched to windows command prompt shell. Also the path should be C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\x86_amd64
However, I still have the VS2010 build error: LINK : warning LNK4044: unrecognized option '/LC:\altera\14.1\hld\board\de1soc\arm32\lib'; ignored 1>LINK : warning LNK4044: unrecognized option '/lalterahalmmd'; ignored 1>LINK : warning LNK4044: unrecognized option '/lalterammdpcie'; ignored 1>alteracl.lib(acl_globals.obj) : error LNK2001: unresolved external symbol acl_hal_get_system_definition I tried compiling vector addition example for AOCL version 14.0 obtained from Altera website and it gave the same error. The options that it complains about being unrecognized are shown when I type aocl link-config. Someone please shed some light on this. - Altera_Forum
--- Quote Start --- I have been able to resolve the AOC unable to find VS LINK.EXE. I was trying emulation from within SoC embedded shell. That was wrong. I switched to windows command prompt shell. Also the path should be C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\bin\x86_amd64 However, I still have the VS2010 build error: LINK : warning LNK4044: unrecognized option '/LC:\altera\14.1\hld\board\de1soc\arm32\lib'; ignored 1>LINK : warning LNK4044: unrecognized option '/lalterahalmmd'; ignored 1>LINK : warning LNK4044: unrecognized option '/lalterammdpcie'; ignored 1>alteracl.lib(acl_globals.obj) : error LNK2001: unresolved external symbol acl_hal_get_system_definition I tried compiling vector addition example for AOCL version 14.0 obtained from Altera website and it gave the same error. The options that it complains about being unrecognized are shown when I type aocl link-config. Someone please shed some light on this. --- Quote End --- ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------say that you installed Visual Studio 2010 and windows SDK7.1, then pls help to follow the following steps which proved work: 11;dConfigure project to use the configuration alteraopencl with the platform x64: Right click on the Project simpleopencl in the Solution Explorer. Click on properties. At the top of the Property Pages, click on configuration manager¡ From the dropdown menus, change the configuration and platform 2. click Close [/B]to close the Configuration Manager. 3.In the Property Pages, go to configuration properties -> general. Verify that the platform toolset has been set to windows7.1sdk. This is what allows us to compile 64-bit executable. 4.In the Property Pages, go to c/c++ -> general. You should see that the additional include directories should include a path to the Intel include files. the include directory allows our compile to be aware of the altera opencl header files.5. Now go to linker->general. You should see Altera¡¯s 64-bit library path listed under Additional library directories. this points the linker to the library directory where intel¡¯s libraries are located.
6. Go to linker->input. In the additional dependencies field, you should see opencl.lib. This is Altera¡¯s provided static library for compiling and running OpenCL kernels. 7. Click ok to close the Property Pages.
[/B]
1. Configure project to use the configuration AlteraOpenCL with the platform x64: Right click on the Project SimpleOpenCL in the Solution Explorer. Click on Properties. At the top of the Property Pages, click on Configuration Manager¡* From the dropdown menus, change the Configuration and platform 2. Click Close to close the Configuration Manager. 3.In the Property Pages, go to Configuration Properties -> General. Verify that the Platform Toolset has been set to Windows7.1SDK. This is what allows us to compile 64-bit executable. 4.In the Property Pages, go to C/C++ -> General. You should see that the Additional Include Directories should include a path to the Intel include files. The include directory allows our compile to be aware of the Altera OpenCL header files. 5. Now go to Linker->General. You should see Altera¡¯s 64-bit library path listed under Additional Library Directories. This points the linker to the library directory where Intel¡¯s libraries are located. 6. Go to Linker->Input. In the Additional Dependencies field, you should see opencl.lib. This is Altera¡¯s provided static library for compiling and running OpenCL kernels. 7. Click OK to close the Property Pages. - Altera_Forum
There has something to set in Project Properties.
please refer to modified project as attached. The execution result as below: Initializing OpenCL Platform: Altera SDK for OpenCL Using 1 device(s) EmulatorDevice : Emulated Device Using AOCX: vector_add.aocx Launching for device 0 (10000 elements) Time: 275.007 ms Kernel time (device 0): 274.017 ms Verification: PASS - Altera_Forum
Have you resolve your problem? I have to say that I have met the same problem with you, can you tell me the solutions? Thank you very much!
http://www.alteraforum.com/forum/showthread.php?t=46646 this is another guy who facing some environment issues, but with VS2013, not sure if this maybe give you some tips to move on?
