11 years agoProblem with compiling host code in VS 2010 and emulation
I am trying out the simple vector addition example given on Altera website. I have AOCL 14.1, Quartus 14.1 and VS2010 installed. I am able to compile the OpenCL kernel without any problem. However...
11 years agosay that you installed Visual Studio 2010 and windows SDK7.1, then pls help to follow the following steps which proved work:
1. Configure project to use the configuration AlteraOpenCL with the platform x64: Right click on the Project SimpleOpenCL in the Solution Explorer. Click on Properties. At the top of the Property Pages, click on Configuration Manager¡* From the dropdown menus, change the Configuration and platform 2. Click Close to close the Configuration Manager. 3.In the Property Pages, go to Configuration Properties -> General. Verify that the Platform Toolset has been set to Windows7.1SDK. This is what allows us to compile 64-bit executable. 4.In the Property Pages, go to C/C++ -> General. You should see that the Additional Include Directories should include a path to the Intel include files. The include directory allows our compile to be aware of the Altera OpenCL header files. 5. Now go to Linker->General. You should see Altera¡¯s 64-bit library path listed under Additional Library Directories. This points the linker to the library directory where Intel¡¯s libraries are located. 6. Go to Linker->Input. In the Additional Dependencies field, you should see opencl.lib. This is Altera¡¯s provided static library for compiling and running OpenCL kernels. 7. Click OK to close the Property Pages.
