13 years agoHi, I just noticed a big mistake on what I wrote.
It should read "If the 8B/10B protocol is implemented correctly and you do NOT send K28.7 symbols, whenever you have a 11_00000_xxx or 00_11111_xxx word in the deserializer, you have a properly aligned word." If you do send K28.7, the concept is the same but it will be a bit more complicated and dependent on what sequences you may send.
