13 years ago --- Quote Start --- The word alignment needs to be done in the deserializer, before the decoder. If the 8B/10B protocol is implemented correctly and you do send K28.7 symbols, whenever you have a 11_00000_xxx or 00_11111_xxx word in the deserializer, you have a properly aligned word. So, you make your deserializer look for those words to find alignment and keep the alignment for any other words. --- Quote End --- Thank you for your answer, i will try to realize this.
