16 years ago
Problem with Clocks
Hi all,
I have following problem. I hafe two clocks on FPGA input, lets say A and B. They are exactly the same and go through PLLs. Clock A feeds a queue which provides data to two registers RA and RB. These registers are clocked with clock A and B correspondingly. The problem is that I have timing violation (setup and hold) on register RB. How can I avoid it or how can I constraint TimeQuest appropriately ?
Best regards
Joel
    hi joel what xactly the path u have provided for the register RB when compared to register RA.. then u can get to the point u need..
    --- Quote Start ---
    Hi all,
    Best regards
    Joel
    --- Quote End ---
    Hi Joel,
    "They are exactly the same and go through PLLs. " Why did you use two clocks ?
    Kind regards
    GPK
