--- Quote Start ---
Hi all,
I have following problem. I hafe two clocks on FPGA input, lets say A and B. They are exactly the same and go through PLLs. Clock A feeds a queue which provides data to two registers RA and RB. These registers are clocked with clock A and B correspondingly. The problem is that I have timing violation (setup and hold) on register RB. How can I avoid it or how can I constraint TimeQuest appropriately ?
Best regards
Joel
--- Quote End ---
Hi Joel,
"They are exactly the same and go through PLLs. " Why did you use two clocks ?
Kind regards
GPK
