10 years ago
Problem with AN351 and VHDL
I am trying to step through the AN351 lab and when I use the Verilog it runs to 2 ms and the transcript window shows "Hello from Nios II!" Now I am trying to use the VHDL test bench, the same steps and everything and runs till 2 MS but I never get any messages besides it converting the signal to x's. I am assuming I am missing a step. Any help would be much appreciated because I primarily use VHDL.
    Hi man, this is some error that might need to talk to local FAE for this.
    You can also try to get help from your local FAE to reduce the TAT.
    Since it seems to be issue with the files coming together with the AN, can try to contact MySupport as citybank mentioned.
    another bad example of an application note, probably some of the procedure are also not up to date.
    Should file a SR and get them update it if found to be valid bug.
    stop spending time to get answer here, go get a job for my altera support, let them handle those bugs !
    Thanks for you replies, by selecting "allow mixed language simulation" it works. Very frustrating
