15 years ago
Problem with ALTPLL
I use a ATLPLL IP In my design. This PLL has one input clock and one output clock.
The input clock is 62.5MHz. The PLL outputs an inverted clock.
I expected the clock max skew from inclk0(62.5MHz) to c0(inverted) is 0.5ns.
The post-sim waveform shows the skew is 10.7ns.
The ALTPLL's connections as below:
DPLL U_DPLL(
.inclk0 (clk_62M ),
.c0 (clk_62M_inv),
.locked (locked )
What's wrong with my design?
Any and all help is very much appreciated
Harris
    I have changed the PLL settings, but the problem is still exist.
    My PLL current settings:
    1. Use the feedback path inside the PLL
    2. In normal mode
    3. The source synchronous compensation mode si disabled by Quartus II
    The c0 is used internal.
    I believe Cris suggets to set it to source synchronous mode instead of normal mode (tick the selection just under normal mode)
    The option In source-synchronous compensation mode is disabled by Quartus II.
    I can not tick the selection.
    My device is Cyclone.
