16 years agoI can't indentify at first look the functional differences between both designs. It seems, that the different behaviour of variable assignments has been compensated by reordering the statements.
But rbugalho is completely right. Using signals as the VHDL equivalent to non-blocking Verilog assignments, you can simply translate the code line-by-line, without needing to reorder anything. By the way, X-HDL is doing a good job in translating Verilog to VHDL and vice-versa. http://www.x-tekcorp.com/xhdl.php
