12 years agoI agree with Tricky that doing the exercise from a scratch is not recommended Forum practice.
as a general guide I will suggest this: your A input goes to a box(possibly register)then to mux then to mult then to register then mux then adder with feedback. 1) Name nodes: A, A_reg, mult_result, mult_reseult_reg, accum_result ...(you may not need naming all) 2) Every mux is equivalent to a conditional statement be it sequential or combinatorial 3) For mult you may just use operator * 4) For add use operator + 5) For any register you may instantiate it but since you are after rtl description then any assignment to a signal inside clock edge puts a register at assignment result 6) You will need to truncate the result (s) back to 8 bits
