11 years ago --- Quote Start --- I forced the install of an older version of libfreetype and now modelsim launches fine but I am unsure of the state of anything else on this machine. I did not use the exact solution recommended in that thread above but may get to the point of doing that now that I understand at least a bit about the problem. --- Quote End --- Just wondering which version of libfreetype you reverted to to make Modelsim launch. I've tried mattaw's fix, and something isn't happy, but it could be the newer version of libfreetype, or possible another dependency. Such a frustrating problem (but I should be used to that after using Ubuntu for a year or two). :(
