11 years agoOkay I'll try this. The Terasic SDRAM program works so I do something wrong. I've found another solution using only the on-chip memory. In Nios II right click on the bsp folder then properties and under Nios II BSP Properties check the reduced device drivers box and the small C library box then apply and run and in my case that works.
I have one solution but I really want to make SDRAM works for my projet so I'll continue. Thank you for your replies. J.
