11 years agoI've tried with the SDRAM (8MBytes), I had no error until I start the Nios II program which said "Downloading ELF Process failed". So I've decided to see how much size the .elf file takes (right click on the .elf then properties) and I have "Size : 432 148 bytes". I do a simple printf("Hello Wolrd !");
So now I don't know why the .elf file can't be downloaded. If you have another suggestion. Thanks a lot ! J.
