16 years ago --- Quote Start --- Hi Guys, I've sovled the problem last night. I added a 18pF capacitor to signal tck and ground. Then all OK. It is strange that there's no waveform difference on oscilloscope between with and without the capacitor. And also JTAG is a low speed bus, which on my board only connect with one device. I guess there might be a weak point on jtag circuit/IO design of cyclone 3 fpga. There used to be same problem on Xilinx spartan3, but now I used the Virtex4, no such a problem any more. --- Quote End --- Hi, maybe you have had very small overshoots at the edges of your Clock signal ?? Kind regards GPK
