13 years agoProblem involving parameters, real type, functions, and port declarations
This one is difficult to explain, so I wrote/tested several examples. These examples are contrived, but they show the problem specifically.
Quartus allows me to resize inputs according to functions performed on parameters, like this:
//This module works fine in ModelSim and Quartus.
//It uses a function on the parameter value to set the number of input bits
module param_function_test1# (
parameter num_bits=3
input in_bits,
output out_bit
//Logic just so the module isn't empty...
assign out_bit = |in_bits;
function integer get_msb(
input integer x
return x-1;
endfunction
endmodule
Okay, now I want a module that sizes a port based on a different function that happens to take a real type.
//This module works fine in ModelSim, but Quartus throws a fit about "some_val" not being constant and real data types not being
//supported
module param_function_test2# (
parameter some_val=3.5
input in_bits,
output out_bit
function integer ceil(
input real x
return ((x - integer'(x)) > 0) ? integer'(x) + 1 : integer'(x);
endfunction
endmodule
Crash and burn. At first I thought maybe Quartus just does not support the real type at all, but then I noticed the "Quartus II Support for SystemVerilog" site lists real and shortreal as: "Supported for parameters." I am only using the real type for a parameter in that block of code, but it appears unsupported. For a reference, I made a module that uses a real parameter and does the same function math without the function call:
//This module works fine in ModelSim and Quartus, implying that Quartus knows how to handle reals in parameters just fine.
module param_function_test3# (
parameter x = 3.5,
ceil = ((x - integer'(x)) > 0) ? integer'(x) + 1 : integer'(x)
input in_bits,
output out_bit
endmodule
That module works as I would hope: Quartus recognizes ceil(3.5) as 4 and gives me a 5-bit input vector. This is frustrating because I often size vectors according to operations on parameters. This means all such math that includes reals has to be done in the module header, which is unfortunate for two reasons: 1) If different modules need the same math, it has to be manually copied and pasted into each module header. I can't package it as a function. 2) Module headers get more cluttered and confusing Will Quartus support constant functions on reals in the future?
