9 years agoProblem in using the same module in project for many times
Hi everyone, I am trying to use one module for several times in one project cause I want to control several ADCs using one main project. And my way to do it is like this:
ADC ADC1(.RS...
9 years agoHi kaz,
Do you think it is OK for me to control these ADCs at the same time? I have checked other things and there are no problem, so I think that it is really my timing problem. And I have no idea how to correct the problem. Quartus said nothing important but told me that I did not assign DOUT1 and DOUT2( they are output of ADCs) as clocks(I got this warning when I were testing one ADC, and it did not matter). My .sdc file is like this:create_clock -name F_CLK -period 20ns -waveform {0 10}
derive_pll_clocks
create_generated_clock -name CLK_REG -divide_by 20 -source }]
derive_clock_uncertainty
create_generated_clock -name CLK -divide_by 1 -source
set_output_delay -clock CLK -clock_fall -max 950ns
set_output_delay -clock CLK -clock_fall -min 50ns
set_output_delay -clock CLK -clock_fall -min 50ns The only two warning I got from quartus are listed below:
Warning (332060): Node: DOUT1 was determined to be a clock but was found without an associated clock assignment.
Warning (332060): Node: DOUT2 was determined to be a clock but was found without an associated clock assignment.
Yours Yonghang Tian
