14 years ago
Problem in SOPC ALTPLL Megafunction-OpenSuse 11.4
Hi, I'm using quartus 10.0sp1 installed on a OpenSuse 11.4 system.
in Quartus I can use the megafunction to create a PLL with no problems whatsoever, but whe i try to instantiate a Avalon PLL in SOPC the megafunction wizard opens, i configure it the way I need, but when i click Finalize, it just doesn't appear on the list, I think it was supposed to create a *hw.tcl file, right? it doesn't. I tried re-installing, and even installing the latest version of Qsys (web edition), the error still occurs...
Does anyone knows what may be the problem?
    i just discovered that if i run quatus as root it works, so I guess it's a permission issue, but I tried reinstalling quartus on my home folder, not using root for anything and the problem still persists... any ideas?
    have you tried newer software? 10.0 wasn't the strongest release even with the service pack
    Thanks for the reply, but yes, like I said, even with quartus 11 running Qsys, the same problem still happens..
    i missed that
    i was able to add an Avalon ALTPLL to SOPC Builder in 11.1 on Centos 5 without root access, so it must be something specific to Suse?
    Weirdly, I added another user and it worked, then it did'nt again, then I deleted the other user and then in my normal user account, it worked.... o.O
    Did you happen to install it as root?
    I ran into a problem when installing 10.1sp1 on Ubuntu as root. It creates a ~/.altera.quartus folder in your home directory with only root permissions. This is where the tools stores your IP search path in SOPC Builder. Since I didn't have write permissions to that directory, it wouldn't store my IP search path when run as user. I wonder if you're running into something similar in which it automatically attempts to modify that file when you generate the PLL from within SOPC/Qsys.
