Altera_ForumHonored Contributor14 years agoProblem in SOPC ALTPLL Megafunction-OpenSuse 11.4 Hi, I'm using quartus 10.0sp1 installed on a OpenSuse 11.4 system. in Quartus I can use the megafunction to create a PLL with no problems whatsoever, but whe i try to instantiate a Avalon PLL i...Show More
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
