16 years ago
Problem in simulation o/p of circular buffer
hello all,
i tried to impelement a circular buffer in quartus II
Code is compiled successfully,,but i am undable to view o/p in waveforms.
Hers the code..
---FIFO buffer
Library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity fifoeda is
generic (
B : natural :=8; -- number of bit
W: natural :=4 -- number of address bit
port (
clk, reset : in std_logic;
rd, wr : in std_logic;
w_data : in std_logic_vector ( B-1 downto 0);
empty, full : out std_logic;
r_data : out std_logic_vector (B-1 downto 0)
end fifoeda;
architecture arch of fifoeda is
type reg_file_type is array (2**W-1 downto 0) of std_logic_vector (B-1 downto 0);
--signal array_reg: reg_file_type;
signal w_ptr_reg, w_ptr_next, w_ptr_succ: std_logic_vector(W-1 downto 0);
signal r_ptr_reg, r_ptr_next, r_ptr_succ: std_logic_vector(W-1 downto 0);
signal full_reg, empty_reg, full_next, empty_next: std_logic;
signal wr_op: std_logic_vector ( 1 downto 0);
signal wr_en: std_logic;
begin
--========register files=====
process(clk, reset)
variable array_reg : reg_file_type;
begin
if (reset='1') then
array_reg:= (others=>(others=>'0'));
elsif (clk'event and clk='1') then
if wr_en ='1' then
array_reg( to_integer( unsigned (w_ptr_reg))):=w_data;
end if;
end if;
--end process;
-- read port
r_data<= array_reg( to_integer(unsigned(r_ptr_reg)));
-- write enable only when FIFO is not full
end process;
wr_en<= wr and (not full_reg);
-- fifo control logic
-- register for read and write pointers
process( clk, reset)
begin
if ( reset= '1') then
w_ptr_reg <= (others=>'0');
r_ptr_reg <= (others=>'0');
full_reg <= '0';
empty_reg <= '1';
elsif (clk' event and clk='1') then
w_ptr_reg<= w_ptr_next;
r_ptr_reg <= r_ptr_next;
full_reg <= full_next;
empty_reg<= empty_next;
end if;
end process;
-- successive pointer values
w_ptr_succ<= std_logic_vector (unsigned(w_ptr_reg)+1);
r_ptr_succ<= std_logic_vector (unsigned (r_ptr_reg)+1);
-- next-state logic for read and write pointers
wr_op <= wr& rd;
process( w_ptr_reg, w_ptr_succ, r_ptr_reg, r_ptr_succ, wr_op, empty_reg, full_reg)
begin
w_ptr_next <= w_ptr_reg;
r_ptr_next<= r_ptr_reg;
full_next <= full_reg;
empty_next <= empty_reg;
Case wr_op is
when "00" => -- no op
when "01" => -- read
if ( empty_reg /='1') then -- not empty
r_ptr_next<= r_ptr_succ;
full_next <= '0';
if ( r_ptr_succ = w_ptr_reg) then
empty_next<= '1';
end if;
end if;
when "10" => -- write
if (full_reg /= '1') then -- not full
w_ptr_next <= w_ptr_succ;
empty_next<= '0';
if (w_ptr_succ = r_ptr_reg) then
full_next <= '1';
end if;
end if;
when others=> -- write /read;
r_ptr_next <= r_ptr_succ;
end case;
end process;
---==================out put=====
full<= full_reg;
empty <= empty_reg;
end arch;
Can anyone help me to figure out bug ??
Ksr
    You dont say if the problem is in simulation or on FPGA.
    I can see a massive problem with the first process - you have r_data assigned outside of a clock, plus it is also assigned from a variable. You cannot have output assigned like this in a process. You'll need to take it out from the process and put array_reg back as a signal like you had before.
    Ive simulated it and it seems to work fine - I get output. Whats the problem you're getting?
    @Tricky,
    sorry its my mistake..i posted the wrong one.
    At first i written that code and later changed it however..
    Yes, my output is outside of the process and my array object is of signal type rather than variable type.
    My prob. is in output waveform i am unable to view o/p in o/p as it is '0' all through input
    and even full,empty signals are inactive.
    update :
    Now i am geting partial o/p i.e., some of the input values are being read with "XX" in between them.:confused:
    Is thr anyway to send my simulatioin waveform to u to figure out whts wrong??
    or else let me know the input values that u used to view waveform..
    KSR.
    "XX" ususally occurs when you are driving 2 signals on the same output, or being a bus, it could be that the bus is unitialised (ie - you're switching to something thats uninitialised.
    To post the waveform, take a screenshot and make a jpg of it and post it here.
    It might be good to post the code you're working with too - the UUT AND the testbench.
    heres my output waveform..
    as u can see the input values are appeared in on output port but some of the values got delayed more. Does this works for ring buffer..and what about full,empty signals???
    btw..i got rid of those dontcare values...
    Thanks a lot for giving me time...
    somehow i lost the names of ports..well, i provide the names here..
    sorry for inconvenience...
    clk
    reset
    wr
    rd
    w_data(input)
    r_data(output)
    empty
    full
    _____________________________
    Library ieee;
    entity fifoeda is
    generic (
    port (
    end fifoeda;
    begin
    process(clk, reset)
    --variable array_reg : reg_file_type;
    begin
    if (reset='1') then
    array_reg<= (others=>(others=>'0'));
    if wr_en ='1' then
    array_reg( to_integer( unsigned (w_ptr_reg)))<=w_data;
    end if;
    end if;
    end process;
    -- read port
    r_data <= array_reg( to_integer(unsigned(r_ptr_reg)));
    --end process;
    begin
    full_reg <= '0';
    empty_reg <= '1';
    end if;
    end process;
    wr_op <= wr& rd;
    begin
    Case wr_op is
    full_next <= '0';
    empty_next<= '1';
    end if;
    end if;
    empty_next<= '0';
    full_next <= '1';
    end if;
    end if;
    end case;
    end process;
    full<= full_reg;
    empty <= empty_reg;
    end arch;
    --- Quote Start ---
    --- Quote End ---
    From that diagram, I have no idea whats what.
