16 years agosomehow i lost the names of ports..well, i provide the names here..
sorry for inconvenience... clk reset wr rd w_data(input) r_data(output) empty full _____________________________ Library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity fifoeda is generic ( B : natural :=8; -- number of bit W: natural :=4 -- number of address bit ); port ( clk, reset : in std_logic; rd, wr : in std_logic; w_data : in std_logic_vector ( B-1 downto 0); empty, full : out std_logic; r_data : out std_logic_vector (B-1 downto 0) ); end fifoeda; architecture arch of fifoeda is type reg_file_type is array (2**W-1 downto 0) of std_logic_vector (B-1 downto 0); signal array_reg: reg_file_type; signal w_ptr_reg, w_ptr_next, w_ptr_succ: std_logic_vector(W-1 downto 0); signal r_ptr_reg, r_ptr_next, r_ptr_succ: std_logic_vector(W-1 downto 0); signal full_reg, empty_reg, full_next, empty_next: std_logic; signal wr_op: std_logic_vector ( 1 downto 0); signal wr_en: std_logic; begin --============================================== --========register files===== process(clk, reset) --variable array_reg : reg_file_type; begin if (reset='1') then array_reg<= (others=>(others=>'0')); elsif (clk'event and clk='1') then if wr_en ='1' then array_reg( to_integer( unsigned (w_ptr_reg)))<=w_data; end if; end if; end process; -- read port r_data <= array_reg( to_integer(unsigned(r_ptr_reg))); -- write enable only when FIFO is not full --end process; wr_en<= wr and (not full_reg); --=================================================== -- fifo control logic --=================================================== -- register for read and write pointers process( clk, reset) begin if ( reset= '1') then w_ptr_reg <= (others=>'0'); r_ptr_reg <= (others=>'0'); full_reg <= '0'; empty_reg <= '1'; elsif (clk' event and clk='1') then w_ptr_reg<= w_ptr_next; r_ptr_reg <= r_ptr_next; full_reg <= full_next; empty_reg<= empty_next; end if; end process; -- successive pointer values w_ptr_succ<= std_logic_vector (unsigned(w_ptr_reg)+1); r_ptr_succ<= std_logic_vector (unsigned (r_ptr_reg)+1); -- next-state logic for read and write pointers wr_op <= wr& rd; process( w_ptr_reg, w_ptr_succ, r_ptr_reg, r_ptr_succ, wr_op, empty_reg, full_reg) begin w_ptr_next <= w_ptr_reg; r_ptr_next<= r_ptr_reg; full_next <= full_reg; empty_next <= empty_reg; Case wr_op is when "00" => -- no op when "01" => -- read if ( empty_reg /='1') then -- not empty r_ptr_next<= r_ptr_succ; full_next <= '0'; if ( r_ptr_succ = w_ptr_reg) then empty_next<= '1'; end if; end if; when "10" => -- write if (full_reg /= '1') then -- not full w_ptr_next <= w_ptr_succ; empty_next<= '0'; if (w_ptr_succ = r_ptr_reg) then full_next <= '1'; end if; end if; when others=> -- write /read; w_ptr_next <= w_ptr_succ; r_ptr_next <= r_ptr_succ; end case; end process; ---==================out put===== full<= full_reg; empty <= empty_reg; end arch;
