17 years agoProblem in passing of Quartus II for ModelSim
I'm working with Quartus II and I downloaded a example about FFT in Altera's site (http://www.altera.com/support/examples/verilog/ver-cascaded-fft-ifft.html) and i have problem with simulation in ModelSim because file "fft72.vo" is generate in the step Quartus compilation. This situation cause the following error: **error: (vlog-7) failed the open design unit file ''fft72.vo'' in read mode. I believe that this archive belongs to the FFT MegaCore, but I am not right this therefore not it meeting in the directory: C:\altera\72\ip\fft\lib.
I'm following the README and I have doubt in step 3 where it says: " select "edit an existing custom megafunction variation" and choose the fft intellectual property (ip) block:..\ifft_fft_unitygain\bft_unitygain.v ". The file that I have choice is bft_unitygain.v and select fft v7.2 in "megafunction name", is not? If not, which? Help me please!!! Thanks!!!
