17 years ago
Problem during synthesization
I tried to synthesize my design in Quartus II version 8.0. During the synthesization, the error is:
Error (10394): VHDL error at zpu_core.vhd(874): left bound of range must be a constant
When i clicked this, the following is highlighted:
stackA(7 downto 0) <= unsigned(mem_read(((wordBytes-1-to_integer(stackA(byteBits-1 downto 0)))*8+7) downto (wordBytes-1-to_integer(stackA(byteBits-1 downto 0)))*8));
When i synthesize my design in Mentor Graphic HDL Designer, this is no problem at all. Maybe the Quartus that i'm using need to configured correctly?? Anyone has idea on this???
Thx
    As you said I defined such an array type in package whose dimensions were generic integers and used this array type in port decleration. In that case, I got errors again because I was not allowed to use generics, I had to use constants instead. This makes my control on my codes very complicated
    I did the previous synthesis in Quartus 8.1 and as I said before it gave me such an error.
    I think Quartus 9.1 is able to solve this case.
    I didn't get such errors when I synthesized my code with Q9.1
    I think Altera solved this "left bound of range must be a constant" issue in Q9.1 even we defined a long std_logic_Vectors with generic intergers.
