13 years agoProblem compiling Matrix Mult example
When compiling the matrixmult example, I get this message below but with no indication as where the errors are! Info (21057): Implemented 96131 device resources after synthesis - the final r...
13 years agoI recommend opening a service request and having the support team at Altera take a look at the log file to see what is causing the issue: http://www.altera.com/mysupport
Also in the top level of the matrix multiplication directory is a readme file that explains how the prebuild .aocx files were generated. Did you use the same instructions or did you just call aoc without any flags?
