13 years agoOh, and depending how you do timing constraints, note that you won't get 100ps variation. Stratix III models on-die variation, so the exact same path in the same corner has a "fast" and "slow" sub-model. So if you use timing constraints like setup and hold, or skew, you'll see a lot more variation. It's not that it's necessarily larger in hardware, but Stratix I didn't model that.
