16 years ago --- Quote Start --- That does not work in practice. After doing what you suggest in the assignment editor, and rerunning synth&elab, the reg is still not available in Node Finder under any of the Signaltap II filters. It is only available under the post-synthesis filter. Likewise for when adding /* synthesis syn_noprune */ directive. Does this capability actually work, or is it just in the manuals? --- Quote End --- Ive had it working fine. In VHDL - best way to do it is to do this:
noprune VHDL Synthesis Attribute signal reg1: stdlogic;
attribute noprune: boolean;
attribute noprune of reg1: signal is true;
