SOkte
6 years agoPreserving an Instance
What is the synthesis attribute for preserving an instance (not register) example: Blockram instance whose outputs are not used.
KennyT_altera
6 years agoyou can set it as a design partition, once it is set. Usually, it wouldn't simply optimized away the output of your block ram. But you had to make sure that your output of the ram is in the boundary of the design partition.
