13 years ago --- Quote Start --- That was badly explained (or you're being daft!). --- Quote End --- Both :) I got the impression that you were putting round pads for the caps directly on the PCB bottom in the identical location to the BGA pads on the top, i.e., the round cap pads lay between the vias. --- Quote Start --- An 0402 footprint with 0.5mm round pads at 1mm pitch can be placed on the back of the board to mirror a pair of BGA balls on the other side. --- Quote End --- Its not mirroring the BGA balls, the caps go on the end of the vias. --- Quote Start --- I drop the vias centrally between the BGA pads with a short stub to the pad on the top layer. I then connect the cap straight to the via on the bottom. --- Quote End --- Now you're talking some sense :) --- Quote Start --- You'll often get a power input and GND BGA beside each other. This allows you to have a CAP directly across their associated vias on the bottom of the board. --- Quote End --- And when you don't, you steal the via from a GPIO pin, and make that GPIO pin unusable. Before I make pin assignments, I determine which power pins are missing ground pins next to them, so I can reserve appropriate GPIO pins. The same goes for configuration signals that need pull-ups or pull-downs (if they do not route out of the BGA). --- Quote Start --- All my vias under the BGA are tented, it's one of the things to check on my PCB signoff checklist! --- Quote End --- Excellent :) Cheers, Daft ... erm ... Dave
