13 years agoput decoupling capacitors on every power pin.
100nF caps are effectively free, and the incidental cost of placing another 20 devices per FPGA in a typical board is again almost zero. Unless you're trying to get the costs down on a board you'll be making 10's of 1000's of you might as well follow this advice. And if you are you should have the budget to experiment. Nial
