sado
2 years agoPower consumption of FPGA maxⅤ and max10
I am currently checking the specs of maxv and max10 in order to select a new FPGA. I synthesized the above devices with the same design and checked the power consumption, and found a large differen...
NazrulNaim_Intel
2 years agoHello,
For your information there is a large difference between the 2 devices is because MAX V architecture provide the MultiTrack interconnect which is designed to maximize performance and minimize power by using the most efficient, direct connection from input to logic to output. For more information regarding MAX V datasheet. You can access the link below.
Link : https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-v/mv51001.pdf
Hop that helps.
Nazrul Naim
