16 years ago
Power Analysis
Let's say my design doesnt fit in the fitter due to excessive IO pins. Is there any other way I can check on the power consumption of my design?
cheers,
clare
    Open the Assignment Editor and list a bunch of your pins. Then make the assignment Virtual Pin = On to them. This will make the I/O become internal registers, so the design can now fit and you can do a power analysis.
    thanks Rysc but i still have problem the design cannot fit in fitter. i got the following error message:
    Error: Selected device has 52 RAM location(s) of type M4K. However, the current design needs more than 52 to successfully fit
    Info: List of RAM cells constrained to M4K locations
    I
    You can right-click on a hierarchy and create a Design Partition. Then go to Assignments -> Design Partition viewer and make it an Empty partition. Everything that hooks up to it will be kept but the contents of that hierarchy will be empty. This is a way to remove logic, but of course the power numbers will be slightly less, and if the final design needs that much memory, it's not a valid solution. It just works for quick tests.
