15 years agoIf you use Quartus II, just do the following:
- create a new file - in the empty editor right mouse button, select insert template - choose VHDL, then Logic, the Registers, the whatever Register posivite edge you like - hit insert - done you get: -- In Altera devices, register signals have a set priority. -- The HDL design should reflect this priority. process(<reset>, <aload>, <adata>, <clock_signal>) begin -- The asynchronous reset signal has the highest priority if (<reset> = '0') then <register_variable> <= '0'; -- Asynchronous load has next-highest priority elsif (<aload> = '1') then <register_variable> <= <adata>; else -- At a clock edge, if asynchronous signals have not taken priority, -- respond to the appropriate synchronous signal. -- Check for synchronous reset, then synchronous load. -- If none of these takes precedence, update the register output -- to be the register input. if (rising_edge(<clock_signal>)) then if (<clock_enable> = '1') then if (<synch_reset> = '0') then <register_variable> <= '0'; elsif (<synch_load> = '1') then <register_variable> <= <synch_data>; else <register_variable> <= <data>; end if; end if; end if; end if; end process; whereas all the <variablename> can be ports, a very simple DFF that can be used as a sheet symbol: -- Quartus II VHDL Template -- Basic DFF library ieee; use ieee.std_logic_1164.all; entity DFF is port ( clk : in std_logic; clk_ena : in std_logic; data : in std_logic; reset : in std_logic; q : out std_logic ); end entity; architecture rtl of DFF is signal internal_state : std_logic; begin process(data, clk, clk_ena, reset) begin if(reset = '0') then if rising_edge(clk) then if(clk_ena = '1') then internal_state <= data; --latch input end if; q <= internal_state; end if; else internal_state <= '0'; end if; end process; end rtl; note: I didn't compile it, but it should work. It lacks async. load, but I never use that, since apart from resets, async designs are a pain in the *bleep*.
