13 years agoPorts between blocks problem
hello every body,
I've multi blocks of "ram_infer" and the same number of "my entire program". I want to make the output of the entire program is the input to ram_infer, but facing error problem from QII. is it correct to make on this way like below? putting RA0-3 as an input and output on the same time. Thanks in advance for your help. :) /////////////// wire [10:0] RA0; wire [10:0] RA1; wire [11:0] RA2; wire [11:0] RA3; generate genvar i; for (i = 0; i < IDE; i = i + 1) begin : IDE_block IDE u(global_reset_n, CLOCK_50, ram_din, di, RA0, RA1, RA2, RA3); end endgenerate generate genvar j; for (j=0; j < SRAM_INFERS; j = j + 1) begin: sram_block SRAM_INFERS x(CLOCK_50, write_a, sram_we,DO, RA0, RA1, RA2, RA3, ); end endgenerate /////////////
