Port "devclrn" or "devpor" does not exist in primitive "dffeas" of instance "gen_dff[...]"
I am instantiating a large number of dffeas through generate statements and receive the following errors for what seems like every generation:
Error(16184): Port "devclrn" does not exist in primitive "dffeas" of instance "g0[9].g1.g3[0].DFFEAS_inst"
Error(16184): Port "devpor" does not exist in primitive "dffeas" of instance "g0[9].g1.g3[0].DFFEAS_inst"
I saw that this was apparently a bug for Arria devices and software 22.2 or earlier. https://www.intel.com/content/www/us/en/support/programmable/articles/000092114.html
Even though I am using a Stratix 10 and am not using HDMI, I hoped upgrading my version of Quartus would fix this. I upgraded Quartus Prime Pro from 21.1 to 22.3 but still received the error.
I am currently in the process of upgrading again to 24.3 but am not confident it will work. Is this in fact a bug? Or is there an error on my end? All of the library modules look correct.
I originally was working on Quartus 21.1 and Synthesizing for a Stratix 10 device. My design doesn't use HDMI.
- RichardT_altera
The error message indicate that;
CAUSE: You connected a port to the specified primitive through the specified port name, but the name does not exist.
ACTION: Make sure that you spelled the port name correctly and replace the port name with a legal primitive port name.
For further detail, please refer to the "Example 2–20. DFF Primitive Instantiation, Verilog HDL" in the Designing with Low-Level Primitives User Guide.
If this error is caused by using an Intel/Altera IP, please share your design .qar file (Project > Archive Project) that can reproduce the issue.
This will allow me to escalate the matter to the IP specialist for further investigation.
Richard Tan
- ZaidSahawneh
I am instantiating these in a custom component. My instantiation reads as follows:
DFFEAS_inst : DFFEAS
port map
Q => f_signal(i)(j), -- Data output
CLK => i_clock, -- Clock input
ENA => '1', -- Clock enable input
D => i_sigin(j), -- Data input
SCLR => i_reset -- Synchronous reset input
--S => '0' -- Synchronous set input
);I do not attempt to use any devclrn port or devpor port but still get the 'port devclrn does not exist in primitive "dffeas" ' / 'port devpor does not exist in primitive "dffeas" ' errors
I went ahead and added them thinking maybe making them explicit would help it connect them. The new instantiation reads as follows:
port map
SCLR => i_reset, -- Synchronous reset input
DEVCLRN => '1',
DEVPOR => '1'
);I still get the same error.
The definition found in [quartus installation dir]/libraries/vhdl/alteradirectory/altera_primitives_components.vhd has both of those signals and the spelling is correct. not explicitly connecting them shouldn't cause an error especially since they have a default value. The definition of the primitive reads as follows:
component dffeas
generic (
power_up : string := "DONT_CARE";
is_wysiwyg : string := "false";
dont_touch : string := "false";
x_on_violation : string := "on";
lpm_type : string := "DFFEAS";
tsetup_d_clk_noedge_posedge : VitalDelayType := DefSetupHoldCnst;
tsetup_asdata_clk_noedge_posedge : VitalDelayType := DefSetupHoldCnst;
tsetup_sclr_clk_noedge_posedge : VitalDelayType := DefSetupHoldCnst;
tsetup_sload_clk_noedge_posedge : VitalDelayType := DefSetupHoldCnst;
tsetup_ena_clk_noedge_posedge : VitalDelayType := DefSetupHoldCnst;
thold_d_clk_noedge_posedge : VitalDelayType := DefSetupHoldCnst;
thold_asdata_clk_noedge_posedge : VitalDelayType := DefSetupHoldCnst;
thold_sclr_clk_noedge_posedge : VitalDelayType := DefSetupHoldCnst;
thold_sload_clk_noedge_posedge : VitalDelayType := DefSetupHoldCnst;
thold_ena_clk_noedge_posedge : VitalDelayType := DefSetupHoldCnst;
tpd_clk_q_posedge : VitalDelayType01 := DefPropDelay01;
tpd_clrn_q_negedge : VitalDelayType01 := DefPropDelay01;
tpd_prn_q_negedge : VitalDelayType01 := DefPropDelay01;
tpd_aload_q_posedge : VitalDelayType01 := DefPropDelay01;
tpd_asdata_q: VitalDelayType01 := DefPropDelay01;
tipd_clk : VitalDelayType01 := DefPropDelay01;
tipd_d : VitalDelayType01 := DefPropDelay01;
tipd_asdata : VitalDelayType01 := DefPropDelay01;
tipd_sclr : VitalDelayType01 := DefPropDelay01;
tipd_sload : VitalDelayType01 := DefPropDelay01;
tipd_clrn : VitalDelayType01 := DefPropDelay01;
tipd_prn : VitalDelayType01 := DefPropDelay01;
tipd_aload : VitalDelayType01 := DefPropDelay01;
tipd_ena : VitalDelayType01 := DefPropDelay01;
TimingChecksOn: Boolean := True;
MsgOn: Boolean := DefGlitchMsgOn;
XOn: Boolean := DefGlitchXOn;
MsgOnChecks: Boolean := DefMsgOnChecks;
XOnChecks: Boolean := DefXOnChecks;
InstancePath: STRING := "*" );
port (
d : in std_logic := '0';
clk : in std_logic := '0';
ena : in std_logic := '1';
clrn : in std_logic := '1';
prn : in std_logic := '1';
aload : in std_logic := '0';
asdata : in std_logic := '1';
sclr : in std_logic := '0';
sload : in std_logic := '0';
devclrn : in std_logic := '1';
devpor : in std_logic := '1';
q : out std_logic );
end component;As you can see the spelling is correct and the signals exist in the primitive library definition. As well as the error occurs even when I do not use those ports.
My library calls read:
library ieee;
use ieee.std_logic_1164.all;
library altera;
use altera.altera_primitives_components.all;
- RichardT_altera
Could you share me the .qar project that could duplicate the error?
I will need to further investigate.
Richard Tan
- RichardT_altera
Any update on this?
Do you able to share the project?
Richard Tan
- ZaidSahawneh
Apologies for the delay.
I cannot share the project but I think I can get a shell together that may do the same thing. I'll try to put it together this week or next. If I can't get one together that recreates the error then I will reply saying so and we can close this item then.
- RichardT_altera
Sure. Do let me know once you able to create a simplified design that could duplicate the error.
Richard Tan
- RichardT_altera
Do you able to share a simplified design to duplicate the error?
Richard Tan
- ZaidSahawneh
Apologies but due to time constraints I wasn't able to do that. For anyone skimming this thread, my solution was to just write my own flip flop and instantiate that instead.
- RichardT_altera
Thank you for sharing your solution.
I understand your situation. In that case, do you need any further assistance from my side?
Richard Tan
- ZaidSahawneh
No more assistance is necessary at this time. Thank you.
- RichardT_altera
Thank you for the confirmation.
Now, I will transitioning this thread to community support. If you have any further questions or concerns, please don't hesitate to reach out. Please login to https://supporttickets.intel.com/s/?language=en_US , view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support.
Richard Tan
