15 years ago
Port "data0" does not exist in primitive "and2" of instance "U1"
Dear my best friends
I'm coding an entity JKFF_TFF and I use MegaWirard function to generate code for and2. After that I copy VHDL code of and2 to the same vhdl file of my entity.
When I compile it have a problem with this notice:
--- Quote Start ---
Error: Port "data0" does not exist in primitive "and2" of instance "U1"
Error: Port "data1" does not exist in primitive "and2" of instance "U1"
Error: Port "result" does not exist in primitive "and2" of instance "U1"
--- Quote End ---
and this is my code:
library IEEE;
use work.all;
USE ieee.std_logic_1164.all;
LIBRARY lpm;
USE lpm.lpm_components.all;
entity JKFF_TFF is
port 	(x,xp	: In STD_LOGIC;
		Z		: Out STD_LOGIC;
		clk		: In STD_LOGIC);
end JKFF_TFF;
architecture structure of JKFF_TFF is
Signal 	a1,a2				:  STD_LOGIC;
Signal	o1,o2,o3,o4			:  STD_LOGIC;
Signal	Y0,Y1,Y2,Y3,Y4		:  STD_LOGIC;
Signal	Q0,Q0p,Q1,Q1p,Q2,Q2p:  STD_LOGIC;
Begin
U1: Entity and2 port map (x,Q1p,a1);
End structure;
LIBRARY ieee;
LIBRARY lpm;
ENTITY and2 IS
	PORT
		data0		: IN STD_LOGIC ;
		data1		: IN STD_LOGIC ;
		result		: OUT STD_LOGIC
END and2;
ARCHITECTURE SYN OF and2 IS
--	type STD_LOGIC_2D is array (NATURAL RANGE <>, NATURAL RANGE <>) of STD_LOGIC;
	SIGNAL sub_wire0	: STD_LOGIC_VECTOR (0 DOWNTO 0);
	SIGNAL sub_wire1	: STD_LOGIC ;
	SIGNAL sub_wire2	: STD_LOGIC ;
	SIGNAL sub_wire3	: STD_LOGIC_2D (1 DOWNTO 0, 0 DOWNTO 0);
	SIGNAL sub_wire4	: STD_LOGIC ;
BEGIN
	sub_wire4    <= data0;
	sub_wire1    <= sub_wire0(0);
	result    <= sub_wire1;
	sub_wire2    <= data1;
	sub_wire3(1, 0)    <= sub_wire2;
	sub_wire3(0, 0)    <= sub_wire4;
	lpm_and_component : lpm_and
	GENERIC MAP (
		lpm_size => 2,
		lpm_type => "LPM_AND",
		lpm_width => 1
	PORT MAP (
		data => sub_wire3,
		result => sub_wire0
END SYN;
I don't know how to solve this problem. Could you help me? Thanks
    --- Quote Start ---
    Thank you.
    I had found the document to introduce this step by step:
    This is my link: http://www.mediafire.com/?iv6v06zs288bdgd
    From page 11 to page 18. But i don't know how to make a state table - High level description (at page 13). Because the original circuit have 5 state from Y0 to Y4 and new circuit have only 3.
    Could you help me?
    --- Quote End ---
    You don't need a complicated state machine approach. All you need - given DFF, how do convert to JK or T.
    Converting JK or T to D is easy but the reverse is a bit more involved.
    I found this circuit for converting D to JK (check if it is correct):
    add two AND plus one Or at front of DFF. The Ored output connects to D.
    (J)---------------and1_input1
    (Q')--------------and1_input2
    Q'---invert-------and2_input1
    K----invert-------and2_input2
    To convert D to T, convert JK to T by wiring the above JK together.
    Thank you so much. You are very kind. I try it now. If I meet error, i hope you will help me again.
