14 years agoNativeLink only has to be re-run after a new HDL file is added to the project. if edits to the RTL are made, pushing up until you see the run command (then enter) is sufficient
you can also use NativeLink to create the initial .do file, edit it to taste, and configure NativeLink to run your edited .do file. you could then copy+paste vcom/vlog lines to add more source HDL
