Steve4's avatar
Steve4
6 years ago
PLL Slave Ports
I'm building a MAX 10 design partially using platform designer. When I try to generate the PLL, additional avalon memory mapped slave ports are included.
This is not something that's covered in the ALT PLL user guide, additionally numerous tutorials have shown the PLL being generated with the absence of the slave ports despite the same settings..
Why are these ports being generated and how do I get rid of them?
  • Hi Stephen Samarzia
    The PLL instantiated from Platform Designer consist of a wrapper for an ALTPLL IP core and Avalon-MM slave interface. You can export this signal if you need it or leave the signal unconnected.
    Alternatively, you can instantiate the ALTPLL IP through IP Catalog. The PLL generated with this won't have this signal generated.
    Eng Wei
  • EngWei_O_Intel's avatar
    EngWei_O_Intel
    Hi Stephen Samarzia
    Eng Wei
      EngWei_O_Intel
      Hi Stephen Samarzia
      Eng Wei
  • sstrell's avatar
    sstrell
    Can you show a screenshot of what you're seeing?
