Steve4's avatar
Steve4
6 years ago
PLL Slave Ports
I'm building a MAX 10 design partially using platform designer. When I try to generate the PLL, additional avalon memory mapped slave ports are included. This is not something that's covered in th...
  • EngWei_O_Intel's avatar
    5 years ago
    Hi Stephen Samarzia
    The PLL instantiated from Platform Designer consist of a wrapper for an ALTPLL IP core and Avalon-MM slave interface. You can export this signal if you need it or leave the signal unconnected.
    Alternatively, you can instantiate the ALTPLL IP through IP Catalog. The PLL generated with this won't have this signal generated.
    Eng Wei
