Steve4
6 years agoPLL Slave Ports
I'm building a MAX 10 design partially using platform designer. When I try to generate the PLL, additional avalon memory mapped slave ports are included.
This is not something that's covered in th...
- 5 years ago
Hi Stephen Samarzia
The PLL instantiated from Platform Designer consist of a wrapper for an ALTPLL IP core and Avalon-MM slave interface. You can export this signal if you need it or leave the signal unconnected.
Alternatively, you can instantiate the ALTPLL IP through IP Catalog. The PLL generated with this won't have this signal generated.
Eng Wei
sstrell
6 years agoCan you show a screenshot of what you're seeing?
