PLL is not fully compensated
Hi @Norick
I am referring to the CLKCTRL before the PLL. See screenshot.
Maybe is the way you instantiate your block that puts the CLKCTRL there.
As for the ClockControlblock after the PLL, that is not related to the warning.
Hello JwChin
now, I think I understand the problem here. First of all the diagram you showed is the Post Fitting Map Viewer. This is quite importand because the other viewers does not show this contolblock at all!
Second, the showed controlblock is not part of my design and therefore I focused on the assignment editor. Here I have seen that the FPGA_CLK1 has been set as "global signal" and was enabled. Therefore
Quartus put in such controlblock before the PLL!
After disabling it the warning messages is gone and everything fine :)
Thank you!
- JonWay_altera7 years ago
You are welcome. I am glad it helped! 😊
