Norick
7 years agoPLL is not fully compensated
Hello in Quartus I get following warning message (same message for PLL_FRT and PLL_ADC_intern): Warning: PLL "PLL_FRT:PLL_FRT_inst|PLL_FRT_altpll_0:altpll_0|PLL_FRT_altpll_0_altpll_nr22:sd1|pll7" i...
JonWay_altera
7 years agoHi @Norick,
Which quartus version?
Which device? PN needed.
Which pin?
It would be great if you can attached a simple design that shows the problem here.
Norick
7 years agoI am using:
- Quartus: 18.0.0 Build 614 Lite Edition
- Max10 10M40DAF256I7G
The used pins of the Max10 are:
- FPGA_CLK1 --> Max10 Pin_K6
- FPGA_CLK2 --> Max10 Pin_J11
The design is shown above. At the moment there is NO special assignement done in order set a specific PLL to a specifif clock source!
Question:
- Do I need to assign a specific PLL to my clock input? If yes, how can I do it?
