15 years ago --- Quote Start --- Suppose I've to transfer data from clk domain to clk/2 then PLL can help reduce the skew on the clk/2, right? --- Quote End --- That is correct. --- Quote Start --- I've added a picture to visualize the problem. --- Quote End --- The picture doesn't match your description. According to the picture, you are not dividing by 2. And what is more important, you are muxing between two clocks, which is quite a different issue. So please let us know exactly what you want to do.
