15 years agoI'm using Stratix III device. I didn't see any restriction on the logic driving the GCLK line (which can feed a PLL).
There are clock muxes (2:1) in the design with each clock being gated before it is fed to the mux. I saw the clock gating is not being turned into register enable. So, I will have to generate the divide-by-2 clock. Thanks, Gopal
