15 years agofrom: http://www.altera.com/literature/hb/cyc3/cyc3_ciii51006.pdf
--- Quote Start --- (3) This input port is fed by a pin-driven dedicated GCLK, or through a clock control block if the clock control block is fed by an output from another PLL or a pin-driven dedicated GCLK. An internally generated global signal cannot drive the PLL. --- Quote End ---
