16 years agoPLL Compensation warning
Hi All,
I have a source synchronous interface where the received clock is driving a dedicated PLL clock input and the PLL being instantiated is configured for source synchronous mode. I've also set the PLL_COMPENSATE assignment on the data input bus pins. The C0 output from the PLL (with no phase adjustment) is directly clocking a megawizird generated ALT_DDIO block, that is also fed by the above mentioned data bus. I'm receiving the following warning though from the fitter: Warning: PLL <removed> in Source Synchronous mode with compensated output clock set to clk[0] is not fully compensated because it does not feed an I/O input register For the life of me I don't see why I'm getting this error. Is the ALT_DDIO block not being placed in flops next to the I/O? I'd appreciate it if anyone has any thoughts on this. Raphael
