12 years agoI'm not sure you state you requirements very clearly. You mention PLLs and counters. Are you expecting to use the PLL to generate a high frequency clock and counters to divide that clock down to the 'synthesised' frequency of choice?
Assuming so - a simple solution: Use Altera's Megawizard to generate a PLL for the particular FPGA family you're targeting. Generate a high frequency clock and feed dividing logic to generate lower frequency clocks. The following link includes simple code to divide down a clock: http://www.asic-world.com/examples/verilog/divide_by_2.html (http://www.asic-world.com/examples/verilog/divide_by_2.html) Regards, Alex
