Please help to fix the errors
When I run the code, I got these errors:
Error (10476): VHDL error at controller.vhd(105): type of identifier "max_add" does not agree with its usage as "std_logic_vector" type
Error: Quartus II Analysis & Synthesis was unsuccessful. 1 error, 0 warnings
Error: Quartus II Full Compilation was unsuccessful. 3 errors, 0 warnings
The code is Here:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity controller is
generic
(WORD_SIZE :Natural :=8;
RAM_DEPTH :Natural :=32;
ADDRESS_LENGTH :Natural :=5);
port
(test_data : in std_logic_vector(WORD_SIZE-1 downto 0);
config_in : in std_logic_vector(WORD_SIZE-1 downto 0);
clk : in std_logic;
nrst : in std_logic;
config : in std_logic;
check : in std_logic;
max_add : in std_logic_vector(ADDRESS_LENGTH-1 downto 0);
mx_add : in std_logic;
samp_out : in std_logic_vector(WORD_SIZE-1 downto 0); --from ram
samp_in : out std_logic_vector(WORD_SIZE-1 downto 0); --to ram
test_en : out std_logic;
test_rdwr : out std_logic;
test_add : out std_logic_vector(ADDRESS_LENGTH-1 downto 0);
test_ok : out std_logic;
see_result : out std_logic;
samp_add : out std_logic_vector(ADDRESS_LENGTH-1 downto 0);
samp_en : out std_logic;
samp_rdwr : out std_logic;
seg_addr : out std_logic_vector(ADDRESS_LENGTH-1 downto 0));
end controller;
architecture BEHAVIOR of controller is
type mem is array (0 to RAM_DEPTH-1) of std_logic_vector(WORD_SIZE-1 downto 0);
signal memory: mem;
type states is (sidle,sconfig,scheck,scompare);
signal state :states;
function CONV_STDLOGICVECTOR(X:INTEGER; SIZE:INTEGER)
return STD_LOGIC_VECTOR IS
Variable RESULT:STD_LOGIC_VECTOR(SIZE-1 downto 0);
Variable TEMP :INTEGER;
begin
if X<0 then
TEMP:=(2**RESULT'LENGTH)+X;
else
TEMP:=X;
end if;
for i in RESULT'REVERSE_RANGE loop
case TEMP mod 2 is
when 0=>RESULT(i):='0';
when 1=>RESULT(i):='1';
when others=>null;
end case;
TEMP:=TEMP/2;
end loop;
return RESULT;
end;
begin
process(clk,nrst,config,check)
variable sample_count:natural;
variable tested_count:natural;
variable success_count:natural;
variable fail_count:natural;
variable max_add:natural;
variable mx_add:natural;
variable address:std_logic_vector(ADDRESS_LENGTH-1 downto 0);
variable test_address:std_logic_vector(ADDRESS_LENGTH-1 downto 0);
variable saddress_rdptr:natural;
variable saddress_wrptr:natural;
variable taddress_ptr:natural;
begin
if(nrst='0')then
for i in 0 to RAM_DEPTH-1 loop
memory(i)<=(OTHERS=>'0');
end loop;
sample_count :=0;
success_count:=0;
fail_count :=0;
state <= sidle;
samp_en <='0';
test_en <='0';
test_ok <='0';
see_result <='0';
test_rdwr <='0';
test_add <= (OTHERS =>'0');
mx_add := 0;
elsif(clk='1' and clk'event)then
case state is
when sidle =>if (config='1')then
samp_en <='1';
samp_rdwr <='1';
samp_add <=conv_stdlogicvector(saddress_wrptr,ADDRESS_LENGT H);
samp_in <=config_in;
state <= sconfig;
--saddress_wptr:=saddress_wptr+1;
elsif(check='1')then
if(taddress_ptr=conv_integer(max_add))then
state <= sidle;
else
mx_add:=CONV_INTEGER(max_add);
samp_en<='1';
samp_rdwr<='0';
address := (OTHERS=>'0');
test_en <='1';
test_rdwr <='0';
test_add <=(OTHERS=>'0');
samp_add <= address;
taddress_ptr :=taddress_ptr + 1;
state <= scheck;
end if;
end if;
when sconfig =>if(config='1')then
saddress_wrptr :=saddress_wrptr+1;
address :=conv_stdlogicvector(saddress_wrptr,ADDRESS_LENGT H);
samp_add <=address;
samp_in <= config_in;
samp_en <= '1';
samp_rdwr <='1';
state <=sconfig;
else
state <= sidle;
memory(sample_count) <=conv_stdlogicvector(saddress_wrptr-1,WORD_SIZE);
sample_count :=sample_count +1;
end if;
when scheck => samp_en <='1';
samp_rdwr <='0';
test_en <='1';
test_rdwr <='0';
if (samp_out/=test_data) then
fail_count :=fail_count + 1;
else
success_count :=success_count +1;
end if;
if(taddress_ptr=conv_integer(max_add)) then
state <= scompare;
tested_count :=tested_count +1;
else
state <= scheck;
saddress_rdptr :=saddress_rdptr + 1;
taddress_ptr :=taddress_ptr +1;
address := conv_Stdlogicvector(saddress_rdptr,ADDRESS_LENGTH) ;
test_address :=conv_stdlogicvector(taddress_ptr,ADDRESS_LENGTH) ;
sam_add <= address;
test_add <= test_address;
end if;
when scompare =>if(success_count >=fail_count)then
test_ok <='1';
see_result <='1';
seg_addr <=conv_stdlogicvector(saddress_rdptr,ADDRESS_LENGT H);
state <=sidle;
else
if(trsted_count = sample_count)then
test_ok <='0';
see_result <='1';
state <=sidle;
else
test_ok <='0';
see_result <='0';
state <=scheck;
saddress_rdptr:=(conv_integer(memory(tested_count) +1));
samp_add <=conv_stdlogicvector(saddress_rdptr,ADDRESS_LENGT H);
samp_en <='1';
test_en <='1';
tested_count := tested_count +1;
test_add <=(others =>'0');
end if;
end if;
end case;
end if;
end process;
end BEHAVIOR;
Thank you in advance
