13 years ago --- Quote Start --- wheres the testbench code? --- Quote End --- I create only two .vhd files. I sent the first one. and this is the second one. I got it wrong? LIBRARY ieee; USE ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all;--std_logic_vector operasyonlarina izin verir.--std_logic_vector'e aritm. islemler uygulamayi saglar use ieee.std_logic_unsigned; --use ieee.numeric_std.all; PACKAGE my_data_types IS TYPE integer_array IS ARRAY(0 TO 5,0 TO 5) OF integer range 0 to 255; TYPE int_arr_out IS ARRAY (0 TO 3,0 TO 3) OF integer range 0 to 255; END my_data_types;
