Please Help, Installing Quartus Device Support
Go to the windows start menu and find the program called "Device Installer (Quartus Prime 18.1)" and then it will prompt you for the .qdz file directory. Select the correct directory and the program will search for all .qdz file and then you can select which device to install. The .qdz file is merely the installer package, until you install it the file does nothing.
For the Cyclone V device, users should try to install the latest available software version supported which is Quartus Prime Standard Edition 20.1 or 19.1 for Lite Edition.
p.s. Don’t forget to Reply, and give Kudos for the Best Answer.
- sstrell6 years ago
Sometimes, Device Installer from the Start menu doesn't work either. I don't know why.
The device installer can be accessed directly at <installation directory>/quartus/common/devinfo/dev_install
#iwork4intel
- MoZdk5 years ago
Thanks the link for dev_install/ worked find; windows could not find it through the start menu, so had to locate it directly.
- mohcine5 years ago
hi,
I do not find the directory that contains the .qdz files.
thank u in advance
Mohcine
- RichardT_altera5 years ago
You can just download the device file shown in the device list from the Download Center for FPGAs.
- T353 years ago
this link is bad
